2000 Chevy Astro Ignition Starter Switch
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEBRENKUS
None of my instruments work, Speed-Temp-Volts-oil-milage... on the dash. Cruise control does not work, turn signals and hazard light out also. When I turn off the car, the radio will stay on until the door is opened, now the AC stays on until the door is opened also. If I gently move the key around in the ignition I can get the odometer to come back on and the AC to turn off. Does this sound like a Ignition Starter Switch?? Does the Ignition Starter Switch control electrical to Blinkers, instrument cluster, AC power and Temp/Distance/Compass in the ceiling and the dash? Truck runs fine, Brake lights, headlights, Everything else works.
Sep 23, 2010 at 2:52 AM
WILLIAM_STELTER
  • 24 POSTS
Its hard to tell without seeing it. But I think it is just a loose wire. As far as the radio staying on my astro van does that too. The air staying on/ never heard of that. I would pull apart the colum and check wires. You might have to check them all the way to the fuse box.
Sep 23, 2010 at 9:57 AM
