2000 Chevy Astro Help with surging problems
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHECART1
I have been having problems with surging/chugging when driving at highway speeds as well as missing while at idle
Sep 19, 2009 at 3:31 AM
  • 75,988 POSTS
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Sep 19, 2009 at 5:45 AM
