2000 Chevy Astro help me pls
2000 CHEVROLET ASTRO
149,982 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVYASTRO110
in the mornning when i try to drive off,my car seems to shake like if theres something cloged . i did complete tune up 4 months ago. just change my fuel filter and pump . no ck engine light on. ill wait half hour before i take off agin it go away but not as much but im able to drive completely . i could put there car on park an try to idle it ,, and it will do the same as if its choking what can it be
Oct 28, 2009 at 3:20 PM
JDL
  • 16,098 POSTS
That spider fuel system is known for problems, the poppets stick after overnight sit, either stick open or closed, either way causes a problem. In the service bulletin, the cleaning procedure is a shop procedure. Don't know if injector cleaner will help or not? If that is your problem?
Oct 29, 2009 at 3:10 AM
