I changed my fuel filter and now when I hit the gas at 40 it chokes
Sunday, May 16th, 2010 AT 10:18 PM
INTERNETMECHANIC
MECHANIC
Use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. If your fully obd1 compliant, check for any applicable mil codes. Sometimes the fuel poppets need cleaning. Right now I suspect a fuel issue, could be something other.
SPONSORED LINKS
Monday, May 17th, 2010 AT 10:53 AM
WESLEY_MYS
MEMBER
What and where are fuel poppets
Monday, May 17th, 2010 AT 11:19 AM
INTERNETMECHANIC
MECHANIC
If you have the spider fuel system, you have to remove the upper manifold to get at them. The best cleaning procedure is a shop procedure. I don't know if injector cleaner in the gas tank will help?
