2000 Chevy Astro heater not blowing in and brakes
24,900 MILES • 6 CYL • 4WD • AUTOMATIC
JBRATD
The fan for the heater and defrost will not blow out. I am having trouble getting to the fuse box. Could it be that or the fan? The fan was making funny noises at different times. Also when we make a hard turn to park in parking lots we put the brakes on and they don't always work good. They seem to skip and I never know if I am going to stop or not, I am going under 5 miles per hour at the time. Thank you..
Nov 21, 2008 at 11:21 AM
AUTOTECH04
  • 16 POSTS
well for your braking situation. u have hydro boost assited brakes that is aided by the power steering system.so if u r turning the steering wheel as u r steping on the brake pedal, u will loose braking efficiency & the steering will get stiff!!.
u might have a shorted blower motor & a burnt out blower motor resistor,they are located under the hood on the passenger side just behind the coolant recovery & washer tank!!!!!
Nov 21, 2008 at 1:21 PM
