2000 Chevy Astro grinding from steering
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUZZY1050
When it's cold, below 45 degrees my steering makes a grinding noise when I make a full turn of the wheel.
Nov 24, 2008 at 12:38 AM
  • 110,246 POSTS
Hi:
Does the sound come from the steering column? If so, the bearing inside the column is most likely the problem.
Nov 27, 2008 at 2:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Grinding noise is probably the power steering pump unless noise is located in steering column as Jacobandnickolas pointed out.
Nov 27, 2008 at 2:50 PM
