2000 Chevy Astro grinding from steering
BUZZY1050
  • 2000 CHEVROLET ASTRO
  • 6 CYL
  • 160,000 MILES
When it's cold, below 45 degrees my steering makes a grinding noise when I make a full turn of the wheel.
Monday, November 24th, 2008 AT 8:38 AM
  • 109,708 POSTS
Hi:
Does the sound come from the steering column? If so, the bearing inside the column is most likely the problem.
Thursday, November 27th, 2008 AT 10:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Grinding noise is probably the power steering pump unless noise is located in steering column as Jacobandnickolas pointed out.
Thursday, November 27th, 2008 AT 10:50 PM
