2000 Chevy Astro Fuel
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
ACPLOWER99
Astro ran fine last night, always starts within few cranks. This morning all it did was crank. What is the problem?
Jan 8, 2009 at 2:46 AM
MOBILEOILANDMORE
  • 39 POSTS
Check the fuelpump relay (switch it with one that you know is good ie. cooling fan, horn etc.) and fuse. if you still have nothing then check your fuel pressure it should be between 55-70 psi. if you have no pressure its the pump. goodluck
Jan 8, 2009 at 3:22 AM
