2000 Chevy Astro Fuel
ACPLOWER99
  • 2000 CHEVROLET ASTRO
  • 6 CYL
  • 154,000 MILES
Astro ran fine last night, always starts within few cranks. This morning all it did was crank. What is the problem?
Thursday, January 8th, 2009 AT 10:46 AM
MOBILEOILANDMORE
  • 39 POSTS
Check the fuelpump relay (switch it with one that you know is good ie. Cooling fan, horn etc.) And fuse. If you still have nothing then check your fuel pressure it should be between 55-70 psi. If you have no pressure its the pump. Goodluck
Thursday, January 8th, 2009 AT 11:22 AM
