2000 Chevy Astro Fam control
ES&DIE
  • 2000 CHEVROLET ASTRO
  • 6 CYL
  • 186,973 MILES
HIGH" speed does not work. All others function properly
Tuesday, June 23rd, 2009 AT 6:41 AM
JDL
  • 16,098 POSTS
Hello, check the front hvac fuse-30 amp, underhood fuse box. That fuse circuit is hot all the time. If the fuse is good and the circuit is hot, you may need to check the feed to and from the resistor assembly. The high speed doesn't use a resistor, but, is wired through the resistor assembly.
Tuesday, June 23rd, 2009 AT 9:21 AM
Related General Content
