2000 Chevy Astro electrical problem
CRICKET
Electrical problem
2000 Chevy Astro 6 cyl Wheel Drive Type unknown Automatic 67000 miles
i have a 2000 chevy astro van and soon after i got an alarm system put in the battery has been dieing. i had the battery and alternator checked and both were in good condition. i had the alarm disconnected and the van still died. i have a stereo system and had the amp unplugged and it still died. i pass charge and get it started but a few minutes later its dead again. i never had a problem till the alarm but even having it disconnected it still died. what could be causing this?
Jan 11, 2008 at 6:45 AM
MASTERTECHTIM
  • 4,750 POSTS
you said i passed charge and it started. i dont know what exactly you mean. does vehicle run for a long time and then you shut it off and it does not restart?
Jan 11, 2008 at 6:53 AM
CRICKET
[quote:77a95c27ab="mastertechtim"]you said i passed charge and it started. i dont know what exactly you mean. does vehicle run for a long time and then you shut it off and it does not restart?[/quote:77a95c27ab]
the van will start after passing charge to it from another vehicle. but when turned off like in 5 minutes it will be dead again. i drove it like 5 miles to move it to another place and it drove fine.with the remote i unlocked/locked it and by the 3rd day the van was dead.
Jan 11, 2008 at 7:32 AM
MASTERTECHTIM
  • 4,750 POSTS
i know you said the battery tested good. replace your battery. trust me put in a new battery.
Jan 11, 2008 at 7:34 AM
CRICKET
[quote:72a764fd52="mastertechtim"]i know you said the battery tested good. replace your battery. trust me put in a new battery.[/quote:72a764fd52]
the battery is like 1 yr old and when checked at the auto shop they said it was good. ok well im gonna get a new one. thanks! :D
mz.cricket
Jan 11, 2008 at 7:48 AM
MASTERTECHTIM
  • 4,750 POSTS
the reason i say this is because ive been burnt by the battery tester. you could have a bad cell in a battery that is fairly new, and this batterys other cells are strong enough to pass the load test. draining a battery dead even just one time can potentially ruin a new battery.
Jan 11, 2008 at 7:57 AM
CRICKET
[quote:e7a98a28d4="mastertechtim"]the reason i say this is because ive been burnt by the battery tester. you could have a bad cell in a battery that is fairly new, and this batterys other cells are strong enough to pass the load test. draining a battery dead even just one time can potentially ruin a new battery.[/quote:e7a98a28d4]
GREAT! thanks you so much for the info. :wink: i'll update you with the stutus.
Jan 11, 2008 at 8:04 AM
