2000 Chevy Astro AC/Heater Controls
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
MCINTIRE2
The heater and AC work just fine, as does the blower motor. The problem is that I don't have any control over where the air goes. It almost seems as if a supply duct has come loose, and all the air is being dumped somewhere behind the dash area. I cannot direct air to the defroster, the dash vents, the floor area, etc. But I can hear the blower running & I can hear air movement. Is there a chance there is a vacuum leak controlling the vacuum motors for the various functions of the controller? What should I look for?
Thank you!!
Jun 6, 2010 at 10:19 AM
  • 110,248 POSTS
Yes, the direction of the air flow is controled by vacuum. That is where I would start. Check under the dash for leaks as well as under the hood. With the engine running, you may get lucky and hear a hissing sound. Check that out and let me know what you find.
Jun 7, 2010 at 1:08 AM
