2000 Chevy Astro
JACANAS123
  • 2000 CHEVROLET ASTRO
Engine Cooling problem
2000 Chevy Astro
My 2000 chevy Astro van is leaking from under the dash in the front passanger side. The leaking is constant and my front vents doesn't work.
Sunday, May 23rd, 2010 AT 6:06 PM
  • 109,885 POSTS
Is it leaking coolant? If so, chances are the heater core is bad. Let me know if it is coolant.
Also, as far as the vents, check to see if there are any vacuum leaks under the dash and the hood. The vent doors are actuated by vacuum. If there is a leak, it won't properly direct the air flow.
NOTE: I have seen broken hoses, dry rotted ones, and under the hood, I have seen ones that collapse when in use. Check for any of those.
Wednesday, June 2nd, 2010 AT 8:17 AM
