2000 Chevy Astro Over Heating & Blowing Cold Air
2000 CHEVROLET ASTRO
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
GERALDMISURACA
I've replaced the thermostat, I drained the radiator and then poured 8 gallons of water through it, and checked the serpantine belt making sure the fan was working properly. So, why is the Chevy Astro (van) still over heating and why is it only blowing out cold air in the cabin??? Heater core? Not flushed thoroughly? If you think it's the heater core, how much and how long of a job is it? Thanks in advance!
Feb 21, 2008 at 10:39 AM
2CARPRO JACK
  • 11,533 POSTS
with a/c the book time is 3.2 hrs of labor.OEM core is around $150.00 Unhook the hoses and see if you can blow through the core, dont use too much pressure or it will rupture th ecore. There is also a heater control valve , be sure it is working. When does it overheat? idling? , driving?
Feb 21, 2008 at 3:14 PM
