2000 chev astro van
VIVCOMES
2000 chev Astro Van 4.3 68,000 all wheel drive have shaking in front end when starting from stop moving at a slow speed gets better when get to a higher speed. jerks when slowing down to a stop.
Jul 7, 2007 at 4:25 AM
LEB
  • 45 POSTS
I'd start with getting the tires checked, rotated and balanced. Although, I would expect the problem to get worse when you go faster.
Once you verify that the tires are good and balanced, I would check the ball joints, cv joints and u-joints. Make sure they don't move when you shake them by hand. Also, check the calipers to make sure they are tight.
LEBoyd
Jul 7, 2007 at 4:47 AM
