1999 Chevy Astro Transmission issues
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
HATTY
The transmission just start hesitating while shifting in to gear just happen a couple of time then last night is just drop out of gear all gears are like Neutral. The engine is running but the car in no go.
We had the tranmission rebuild twice already the last time was at about 160,000.
What do you think.
Mar 17, 2010 at 4:10 AM
HMAC300
  • 48,601 POSTS
first check the fluid to see if it's full. If it is and is brwon or smells burnt you probably fried the trans and it's best to take it to a trans shop. But with the mielage it may be time for a rebuild or a junk yard one.
Mar 18, 2010 at 3:01 AM
