Hi:
That could be a lot of things. First, what kind of noise is it? Could the PS pump be low on fluid? Could there be a loose belt? If not, there could be a problem with a steering component such as tie rods, ball joints... It could also be control arm bushings. Look under the vehicle to see if anything is broken.
Let me know what you find so I can better help you.
Oct 13, 2008 at 3:08 PM
