1999 Chevy Astro passanger window doesnt work sometimes
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAFAL81NY
When i open the passanger window below some point it stops and it doesnt go up or down. doesnt matter if I try from passanger or driver side then i wait for about 5 minuts and it works for a minut then it stops again so i have to wait couple minuts and it works again for moment.
Apr 29, 2009 at 2:08 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely a bad window motor.When they go bad they can draw too much amperage and cause the breaker to kick, disrupting power for a few moments til it cools again.Remove the door panel and see if the motor is getting power with a test light
May 1, 2009 at 1:00 AM
