1999 Chevy Astro oil pump
1999 CHEVROLET ASTRO
140,000 MILES • 4 CYL • AWD • AUTOMATIC
YAMAHA5464
What would it cost and is it a hard job to replace oil pump
Mar 9, 2008 at 4:45 PM
What's wrong with the oil pump that you are replacing it-is it due to low oil pressure? Might not be the oil pump
Mar 9, 2008 at 4:59 PM
YAMAHA5464
Yesterday I put on about two hundered miles and parked in the garage......got up this morning to leave and I have a knocking noise from the engine....check oil level and was all right........ pressure gauge shows 40 at idle and then put it in gear it pegs the indicator at 80 and gets real loud. Any ideas......Thanks
Mar 9, 2008 at 5:23 PM
80psi is too high -get the oil pressure check-knocking noises is normally caused by low oil pressure/engine bearings/oil pump failure-sounds like the oil is not circulating properly-
Mar 10, 2008 at 5:31 AM
