1999 Chevy Astro no spark
134,128 MILES • 6 CYL • AWD • AUTOMATIC
JJDCHEVY
i changed coil an ing module and now im not getting spark it ran crapy before now it wont run what should i be lookin at
Aug 4, 2008 at 7:18 AM
JDL
  • 16,098 POSTS
Did you do any testing, before you replaced anything? Any codes?
Use a spark tester on the coil wire or hold it close to an engine ground, while a helper cranks the engine, is there any spark? Is the coil wire ok?
You could also check for B+ and ground at the coil primary wires. Pink is B+ goes hot when you turn on the key, white with black tracer is ground, there should be a pulse on that wire with the engine cranking.
The rpm signal comes from the crank sensor, hall switch, three wires, ref voltage--ground-- signal. You can check those circuits.
Aug 5, 2008 at 5:59 AM
