1999 Chevy Astro Lock Actuator
1999 CHEVROLET ASTRO
91,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAGMAN
I am trying to replace the lock actuator on the passenger side door. I was able to remove the door's interior "skin" and have located the lock actuator. I can see that it's attached to a bracket which is attached to the door's interior by two screws that face out and are secured by two washer type nuts that I cannot remove. I can't grab hold of them. If I could remove them then I could remove the actuator and replace it. Do I need a special tool to do this or is there some trick I don't know about?
Thanks for your help.
Oct 29, 2008 at 7:28 PM
