1999 Chevy Astro fuel filter replacement
1999 CHEVROLET ASTRO
92,031 MILES • 6 CYL • 2WD • AUTOMATIC
DANFISCHER
location of fuel pump.
replacement instructions.
Nov 28, 2009 at 9:03 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Welcome to the forum, the fuel filter is located under the vehicle, driverside, in front of fuel tank, in the fuel line. My info shows a threaded fitting on both ends, use a couple of wrenches. Make sure there is no pressure on the system, before you take anything loose. You may need to loosen the gas cap. The pump is in the gas tank.
Nov 28, 2009 at 9:29 AM
