1999 Chevy Astro engine turns over wont start
1999 CHEVROLET ASTRO
HELP1971
1999 Chevy Astro All Wheel Drive Automatic 160000 miles
my security light stays on blinking and the engine will fire but wont run how do i fix this i think it is a electrical problem
Oct 18, 2009 at 3:17 PM
MATHIASO
  • 1,209 POSTS
the computer is responsable for shutting down the starter, the fuel system and lock the car.
an alarm is triggered if the computer loses a ground signal from any of the switches.
the answer to your question is yes.
Here is a list of switches you should start to look:
check door switches for corrosion, or door switch that is stuck( located at door jam of each door)
Door key cylinder switches(attached to key cylinder on the left and right front door)
hood switch ( location, top of inner fender)
Trunk switch (trunk latch)
Trunk key cylinder switch( attach the trunk key cylinder)
Door lock atuator ( part of door lock atuators in each door)
ignition key "in" switch( part of ignition cylinder assembly.
check for corrosion, looseness, or switch that is stuck in.
Oct 19, 2009 at 3:32 PM
