1999 Chevy Astro coolant leak
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEF87571
I have a 99 astro and there is alot of coolant leaking from under the transmisiion or I assume it is coolant because the coolant tank was empty then I filled it and it was empty an hour later but the van runs fine the engine temp is about 140-160 and I can not hear any boiling or wierd sounds and the van runs fine what could this be?
Aug 10, 2010 at 7:26 PM
  • 31,937 POSTS
Hi there,
you may have a heater hose leaking or a core plug leaking, you will have to get a cooling system pressure test to positively identify this leak.
Mark (mhpautos)
Aug 10, 2010 at 8:42 PM
