1999 Chevy Astro clunk noise
143,300 MILES • 6 CYL • FWD • AUTOMATIC
ASTROHELP
The best way I can describe it is a clunk noise mostly when turning right from a slow speed or a complete stop. It seems like it comes from passenger side front.
Jul 20, 2010 at 3:04 PM
FACTORYJACK
  • 4,159 POSTS
Could be a worn, or loose suspension component. If you raise each front wheel with weight supported under the lower control arm, you may be able to feel looseness when the wheel is grasped and rocked at 12 and 6, and also 9 and 3(clock position). I would suspect a ball joint or control arm bushing, but you may find wheel bearings, or loose steering components as well.
Jul 20, 2010 at 4:05 PM
