1999 Chevy Astro Brakes Squealing While Driving
127,986 MILES • 6 CYL • 2WD • AUTOMATIC
AMARANTH
  • 6 POSTS
Brakes squeal or squeak while I am driving and stop when i hit the brakes or when I am at a stop or just idling. When It is cold or wet it also stops as well. at first it was just a faint sound, almost a knocking sound so I thought it was a muffler problem but then it turned into a squeaking that grew louder and louder over time. What is happening?
Dec 31, 2009 at 1:03 AM
BLACKOP555
  • 10,386 POSTS
sounds like you need the brakes to be lubed up on the slides, anti rattles and shims.
Dec 31, 2009 at 5:02 AM
AMARANTH
  • 6 POSTS
I am not even sure what all of that is.
Jan 4, 2010 at 12:01 AM
BLACKOP555
  • 10,386 POSTS
you want to do this all yourself? im not sure thats a good idea if you don't know what the parts i just listed are.
the knocking noise could be a sign of a loose caliper or bad bearing or a worn bushing. as a muffler doesnt normally knock
Jan 6, 2010 at 12:38 PM
