1999 Chevy Astro Brakes pulling
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
1600SENSIBLE
  • 6 POSTS
When coming to a fairly hard stop the van wants to pull to left. Also when driving slow (30 and below) the van wants to fade left. I guess a new caliper. Which one or both? May idler arms? Can a rookie do the adler arms? thanks
Feb 20, 2009 at 3:39 AM
2CARPRO JACK
  • 11,533 POSTS
alot of brake pulls are alignment issues due to worn parts.You can do the idlers yourself, you will need a "pickle fork" to seperate the idlers from the center link. Have the van aligned when done and the brake pull and fade may go away
Feb 21, 2009 at 12:24 AM
