1998 Chevy Astro winshield wipers
LIRPA
Electrical problem
1998 Chevy Astro
My winshield wipers will occasionally come on but only work a few rounds before quitting. Is it the motor or the switch? THANKS FOR THE HELP !
Nov 10, 2008 at 1:18 AM
  • 110,248 POSTS
Hi:
It could be either the switch, the motor, or other problems. What I need you to do, is when the wipers don't work, unplug the motor under the hood and see if you're getting power to the motor. If you are, replace the motor. If not, you should follow the power lead back to the switch to check for a broken or damaged wire. If the wiring is good, replace the switch.
Nov 12, 2008 at 3:54 AM
