1998 Chevy Astro Trans Code P0753
1998 CHEVROLET ASTRO
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRBILL2008
Ongoing issue here first started out with code P0756 and stuck taking off in 2nd gear. Then problem went away and was running fine. Replaced battery after it died and now taking off in 2nd gear again with a code P0753. Nothing aftermarket installed on this van. Factory lock and unlock remotes. Any suggestions woulb be appreciated.
Oct 20, 2008 at 3:13 AM
SWILLIAMS
  • 597 POSTS
Sounds like either the solenoid pack is failing or the wiring harness internal to the trans is shorting. They are both items that could cause this. They can be replaced without pulling the entire trans.
Oct 21, 2008 at 7:10 AM
