my code scanner gives me three codes. po102 maf or vaf acircuit low input. po301 cylinder 1 misfire detected,and po420 catalyst efficiency below threshold. somebody told me thay think it may be a stuck valve. ive changed the sparkplugs,plug wires,pvc,airfillter,and oil change.im getting the same code readings.befor i spend more money.what do you think.
May 4, 2008 at 4:04 AM
