1998 Chevy Astro 98 Chevy Astro
IHAPBONMYC
  • 1998 CHEVROLET ASTRO
  • 6 CYL
  • AWD
  • 158,000 MILES
I have a 1998 chev. Astro that has a problem starting when it is very cold out. It tends to flood and will not start at all. Or it starts and runs rough. The engine check light is on, had it checked, and it coded engine missing. I can drive it but it is using excessive amount of gas.I have changed plugs, plug wires, cap, and roter. When changing plugs, I found that number 4 cylindar spark plug was kind of dark; Like it hasn't been running clean. Does this sound like I have a fuel injector stuck open on number 4? And if so can I just change just the one injector?
Wednesday, January 23rd, 2008 AT 11:40 PM
BMRFIXIT
  • 19,053 POSTS
I would start with cap and wires first
and check coolant and map /mass sensor
Sunday, January 27th, 2008 AT 12:29 PM
