1998 Chevy Astro Rear Door Latch
MHJAMESON
1998 Chevy Astro
How does the rear door latch mechanism go together? Mine is broken and I have to crawl through the van on the inside to manually pull the down rod.
Aug 9, 2009 at 10:45 AM
TECHMAN1
  • 82 POSTS
[quote:63305e8834="mhjameson"]1998 Chevy Astro
How does the rear door latch mechanism go together? Mine is broken and I have to crawl through the van on the inside to manually pull the down rod.[/quote:63305e8834]
I think that you will find that you need to replace the outside plastic handle. If you remove it, it think you will see that a plastic wedge plate has broken off. While you have the covers off, oil all the moving parts well and it should be OK for a couple years.
Ken
Aug 26, 2009 at 4:24 PM
