1998 Chevy Astro P0305
110,000 MILES • 6 CYL • AWD • AUTOMATIC
TRINBAGO63
Good Morning, I am receiving a Service Engine soon light on my Chevy Astro LS. I had a tune up this weekend but the light came back on once I started driving. My mechanic used the ODB scanner and the error code was P0305. He suggested I go to the Dealer because he thinks it's an injector problem. Please advice. Thank you.
Michael
Jul 27, 2009 at 3:36 AM
HMAC300
  • 48,601 POSTS
p0305 is a cyl 5 misfire. check to see if the wire came off the plug or you could have a bad plug as well. It could also be the injector but check the simple stuff first as it was just tuned up. It could be a bad wire as well. The mechanicn should have checked that first.
Oct 2, 2009 at 3:04 AM
