1998 Chevy Astro No Spark
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
GPMARS
I have power to the coil, no spark out. I changed the pick up and the coil-no spark! I also changed the ignition module, still no spark. Any suggestions?
Nov 5, 2009 at 10:40 AM
  • 75,988 POSTS
If its a distributor driven igintion system -check and test the distributor pick-up coil and air gap. If its a DIS check and test the crankshaft positioning sensor.
Nov 5, 2009 at 10:48 AM
