1998 Chevy Astro knocking
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEDRAGN1
  • 10 POSTS
On the way home a month or two ago, my astro van developed a real bad knock. It started out for a couple of miles when you pushed the accelerator and let go, you heard some tapping. That eventually got louder then all the sudden a terrible knock. I can't remember if it had loss of power or not. It's been sitting in the driveway for a couple of months b/c I just don't know what to do with it. I took off the belt to isolate and it still does it. It will start up perfect and idle fine, just with a very loud knock and a little squealing, all without the belt on. No engine light of course but where do you think I should start to look? I may just sell it for parts but I need to know what I'm up against. Thank you, Justin.
May 6, 2008 at 2:35 PM
  • 31,937 POSTS
Hi there,
this sounds like a terminal bearing knock, i would see what the oil pressure is, but i feel it is past reasonable help.
Mark (mhpautos)
May 6, 2008 at 6:59 PM
THEDRAGN1
  • 10 POSTS
The oil pressure is normal. Any ideas? Thanks, Justin.
May 7, 2008 at 3:40 AM
