My 98 astro awd has an intermittent shudder like driving over rumble strips at a turnpike exit alert and a whine or growl like mud grips on pavement(pass. Side). When van shudders, I tap on brake lightly and shudder stops. I already paid to have the c-v joint, hub, bearing where drive shaft goes into front pumpkin replaced.I found axle rod had slipped out of placein pumpkin and into c-v and damaged splines. He dressed splines and reversed shaft. Paid "mechanic" over 1000.00 for several wrong guesses at the problem.I can't send a donation right now, I will definitely be able to do so as soon as I fix the van and my money isn't the retirement fund for "mr wrong wrench". Can you please give me a clue as to where to start, My son has mechanic training but no drive train exp. He will be doing the work. PLEASE HELP!
SPONSORED LINKS
Wednesday, February 27th, 2008 AT 10:14 PM
