Electrical problem
1998 Chevy Astro 6 cyl All Wheel Drive 145000 miles
My door locks keep locking andunlocking the only way to stop them is to pull the fuse help I can not open the back door with out power
Tuesday, December 23rd, 2008 AT 3:59 PM
MECHANIC
Hi:
It sounds like there is a short in the switch, most likely the driver's door switch. You will need to remove the door panel to get to the switch. Remove it and have it tested.
