1998 Chevy Astro 1998 Astro Oil Pan Removal.
225,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARGUY
I have tried to remove the oil pan on my 98 astro 4.3. I have all the bols removed but it will not come off. What all needs to be removed to get the oil pan down?
Thanks
May 20, 2009 at 12:07 PM
TECHMAN1
  • 82 POSTS
[quote:8d44b773e5="carguy@home"]Engine Mechanical problem
1998 Chevy Astro 6 cyl Two Wheel Drive Automatic 225000 miles
Thanks
Joe[/quote:8d44b773e5]
You are asking a question here without giving a problem or symptom. So I am wondering why you are removing the oil pan. Anyway, if you have all the bolts out, beat on it with a rubber hammer or a block of wook.
May 21, 2009 at 2:49 PM
CARGUY
I need to remove the timing cover so i can change the timing chain. The cover won't come off with the oil pan in place. I have tried beating it with a rubber mallet with no luck. Does the trans need to be loosened from the block first?
May 22, 2009 at 2:28 AM
