I have a 1998 Chevrolet Astro Van 3.4L. It came to a point where the van would not start. I changed the rotor, the air filter, the spark-plugs, and the ignition coil, the van would not start. I took it to the mechanic, left it there. He said a wire was lose he was not very specific. I took the van home, next morning did not start. I took it back to the mechanic and I found-out that he starts the van by spraying starting fluid in the air intake, he can't find the problem. The fuel pressure is about 60 which I think is ok. I took the van home and the only way I am able to start it is by praying starting-fluid in the air-intake. COULD SOMEONE TELL ME WHAT MAY BE THE PROBLEM.
My e-mail is: estebanv@verizon. Net
thank you.
SPONSORED LINKS
Tuesday, June 2nd, 2009 AT 5:09 PM
