1998 Chevy Astro
DPLEON
  • 1998 CHEVROLET ASTRO
1998 Chevy Astro
Brake pedal needs to be depressed all the way to stop the vehicle, yet brake fluid is fine. Do not see any fluid leaking from around the wheels. Any suggestions as to the problem
Friday, November 21st, 2008 AT 11:58 AM
AUTOTECH04
  • 16 POSTS
U might have an internal leak in the master cylinder.
First thing is bleed the braking system to make shure there is no air in the system & retry. If its still the same I would try a master cylinder !
Friday, November 21st, 2008 AT 9:24 PM
DPLEON
I bled the brakes and changed the master cylinder and still have a spongy pedal.
Monday, November 24th, 2008 AT 12:30 PM
AUTOTECH04
  • 16 POSTS
If u have ABS on ur van! I am certain that u do, there might be an air pocket traped in the ABS unit. If u have a veh diagnostic tool you will need to activate the ABS unit in order to pass the air pocket from the unit & rebleed the system ! If u don't have 1 u will need to go to a dealer or a local repair shop & have it done there.
I hope the helps !
Monday, November 24th, 2008 AT 7:49 PM
DPLEON
Thanks I will try that
Tuesday, November 25th, 2008 AT 7:20 AM
DPLEON
I am not sure how to do that. Is that using the diagnostic tester?
Tuesday, December 2nd, 2008 AT 11:22 AM
