1998 astro - 82K - tapping
DC -IN-MD
I was wondering if you might have some suggestions.
My Astro started tapping last night when I got home from work. It was running fine when I shut it down and I did not notice any tapping. I went out about an hour later to run my daughter to a doctors appointment and when I started it up.. tick, tick, tick. Very loud.
I checked the oil, it's not due for a change and the level is good from the last oil change. It's due for a change in about 1500 miles. Oil pressure is good. Coolant level is good.
background. Over the last couple of years the van has had several episodes if running ruff. Ultimately I had a full tuneup done and the wires replaced and she ran like a champ for about a year or so. Over the past several months it has started to do something strange. When I start it up in the morning it runs great. I take out and get about a mile or two down the road and it will start to miss. It will miss for about 1 minutes or so, than straighten out and run fine. About a month ago while I was driving it to work I the service engine soon light came on. I put it in the shop and they ended up replacing #3 plug. That took care of the problem. (for then). Yesterday on the way to work I noticed the old problem creeping back in. Not as bad this time but a definite miss.
NOW the tap.. tap.. tap...
Any suggestions????
Thanks
Jun 12, 2007 at 3:15 AM
SHAWN0314
  • 6 POSTS
i have used this stuff it's called b-12 chemtool its at walmart, it cleans up the intake, exhaust valves everything, i used it in a high performance motor in my f-250 4x4 . it might take care of your tapping problem, shawn
Jun 14, 2007 at 10:55 AM
