1997 Chevy Astro turn signals
171,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISPITMAN
  • 10 POSTS
the turn signals do not flash or come on at all. The hazard lihgts do flash. The chime on this circuit works. the brake lights work. If the turn signal lever is left on too long the fuse blows and none of the above work.
Mar 9, 2010 at 11:26 PM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. The problem may be in the steering column or multifunction switch. If you want to do some circuit testing, we can give you wiring colors, whatever you need. You can unplug the combination flasher, use a digital multimeter in place of the fuse. If the meter gives a reading, it's going to ground, somewhere.
Which fuse is blowing?
Mar 10, 2010 at 1:16 AM
CHRISPITMAN
  • 10 POSTS
Fuse # 1, 20amp is the one affected.
Please tell me more about how to perform the test involving the removal of the flasher. Could the problem be the flasher module? How do I test the flasher module?
How do I perform circuit testing to track down the problem? Knowing the wiring colors and functions would be advantageous Does testing for a problem in the steering column and multifunction switch inoilve disassembly in those ares. If so, I would be very concerned about activating the airbag so how would I disable the airbag
I also thought about the towing harness being the problem.
Mar 10, 2010 at 10:46 PM
JDL
  • 16,098 POSTS
My info shows fuse1--20 amp is stop/haz fuse. If that fuse is blown, how come the brake lites work?
https://images.2carpros.com/forum/automotive_pictures/170934_astro_turn_1.jpg
Some automotive forums won't talk to you about air-bags, because of the safety issue. If it blows-up in your face, that is your responsibility.
https://images.2carpros.com/forum/automotive_pictures/170934_airbag_1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_airbag_2_1.jpg
Mar 11, 2010 at 2:11 AM
CHRISPITMAN
  • 10 POSTS
Going back to my initial post the brake lights, hazard lights and chime don't work if the fuse is blown
Thanks for the info.
Mar 13, 2010 at 3:10 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 15, 2010 at 9:59 AM
