1997 Chevy Astro Trans doesnt shift any gear
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALEXPERFORMANCE
I recent bought a tranmission for my Astro, the transmission (4l60E) comes from a Newer model (Blazer extreme 2003), i recent installed but transmission doenst shift any gear, the new tranmission got only 20,000 miles on it. All conections are correctly plugged. Can the cluth converter be the problem or the Codes???
Thank You
Jun 23, 2008 at 3:57 PM
2CARPRO JACK
  • 11,533 POSTS
If the fluid level is good and everything is plugged in , scanning it may not be a bad idea.If the PCM sees something wrong it may have stored a code .
Jun 24, 2008 at 12:44 AM
