1997 Chevy Astro power windows
1997 CHEVROLET ASTRO
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
THGFA
My power windows do not work neither side nor does the radio is all that related how do I fix.
or change over to a manual window
Jun 28, 2008 at 4:21 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Check the 30 amp circuit breaker for the power window, there may be other systems that also use a 30 amp breaker, if their the same just swap them out, see if it makes any difference. Also, with the key on, check for voltage where the breaker plugs in.
If all that checks out, you need to get at the circuits going to the master switch, check for b+ and ground at the master switch. The yellow wire is voltage, you need to have the key turned on to check for voltage. The black wire is ground. If you have good B+ and ground, there may be something wrong with the master switch.
Jun 28, 2008 at 11:05 AM
