1997 Chevy Astro inside [anel gauages not working enlcudes
1997 CHEVROLET ASTRO
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOPEZCLUB
my gas water battery spedomiter odemiter light all went out . sat for 1 day and stared again then quite 5 min later. i checked the fuses and nothing says for insde stuff. no sure what else to ck maybe relay or is it my instrument cluster that went out. i have cked on the price of that and it is 400.00 to order . i s htat the tru price and at only dealer place.
can you please let me know
sylvia
Feb 21, 2010 at 5:12 AM
JDL
  • 16,098 POSTS
hi, are you saying the gages don't work or you don't have any dash lites? Just to add, check 10 amp gage fuse, use a testlite. You shouldn't need to pull fuse, there should be a bare spot over each fuse leg. Use the testlite, one end of lite goes to chassis ground, metal part of vehicle, the pointed end, touch each fuse leg. Test with key on, if each fuse leg is hot, the lite comes on, showing that the fuse is good and there is voltage on the circuit.
Feb 21, 2010 at 5:25 AM
