1997 Chevy Astro drl
1997 CHEVROLET ASTRO
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISPITMAN
  • 10 POSTS
The DRLs won't come on eventhough indicator on dash says they are on.
Jul 19, 2010 at 2:21 PM
  • 110,240 POSTS
Have you checked to make sure the fuses are good as well as the bulbs? Also, is the parking brake switch working and adjusted properly. Many won't turn on until the park brake is released.
Jul 19, 2010 at 3:59 PM
CHRISPITMAN
  • 10 POSTS
Could you elaborate on the location and proper adjustment of the parking brake switch?
Jul 21, 2010 at 9:54 AM
  • 110,240 POSTS
It is located on the park brake assembly. You need to sort of craw under the dash to get a look at it. Once located, you just need to make sure the switch is being actuated by the brake pedal.
Jul 21, 2010 at 4:24 PM
