1997 Chevy Astro air won't blow through registers
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
AVSOLUTIONSLLC
Just bought this cargo van. The air won't blow through the front registers. It does blow at the floor and through defrost. I hear the fan blower working through all speeds. I checked the fuses and the relays. I hear the compressor going off and on and feel a hint of cold air trying to come through. I pulled off the shroud where the air chamber is, below the air bag. There is a piston type plunger on the right of it that looks like it opens and closes a flap or something that redirects the air from floor to top registers?. No matter what I do with the settings on the dash, the plunger doest't move. I manually moved it with my hand and I hear different sounds, but no air once again through the registers. Any ideas? Thanks, Gary Smith
May 3, 2008 at 6:25 AM
MASTERTECHTIM
  • 4,750 POSTS
your problem is a broken vacuum line coming from the intake manifold going to the vacuum port of the dash. the easiest way to repair this is to remove the dog house and run a rubber vacuum hose instead of the broken plastic one. the line runs from the intake to a vacuum line under the hood that comes out of a wiring harness. its hard for me to explain exactly what it looks like but if you look at the middle area of engine from under the hood you will see a vacuum line running from the pass side to the engine on the drivers side. this is the line that breaks. let me know how you make out
May 3, 2008 at 6:37 AM
