1997 Chevy Astro air-condition (refrigerant line) gouged
129,000 MILES • 6 CYL • 2WD • AUTOMATIC
1997ASTROVAN
1997 Chevy Astro: the A/C has not been operational for almost one year. I recharged it with 134A, but it won't hold the charge. I am unable to locate the leak. I inspected an a/c line under the vehicle, and notice part of the hard line has a deep gouge against the engine block, close to where it is clamped and secured. I disconnected the line in the rear (fromt he B-nut), and noticed coolant fluid leaking. Isn't this suppose to be a refrigerant line. The a new line is more than $200. I need professional advice on this matter. After careful inspection, the gouged wasn't deep enough to create a pin hole. So I assume the leak is somewhere else in the system.
Feb 9, 2009 at 3:53 PM
  • 110,246 POSTS
Hi:
Trying to find a leak like this is very difficult. What I recommend is having a shop check it out with equipment that can identify where the leak is coming from. Otherwise, you may be looking for a long time and necer find it.
Mar 23, 2009 at 6:38 AM
