1997 Chevy Astro After removing bolts can not get oil pan g
1997 CHEVROLET ASTRO
171,000 MILES • 6 CYL • 2WD • AUTOMATIC
CASTERS1
MEMBER
1 POST
after removing bolts can not get gasket to let go what will work
Aug 17, 2009 at 1:13 PM
BLUELIGHTNIN6
✓Experienced Mechanic
pry up on one portion with flat tool and work your away around. or use a small rubber headed mallet and gently tap on the edge of pan to loosen it up
Aug 17, 2009 at 4:42 PM
