1997 Chevy Astro AC stops blowing out of dash vents at high
1997 CHEVROLET ASTRO
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
MASONC
The ac in my 97 astro van works fine when I drive around town and on the highway. As soon as I hook my camping trailer to it, the ac works until I hit 50 miles per hour then the air from the vents goes away. I let off the gas and go below 50 it comes back on. accelerate agian and once I hit 50 the ac stops blowing out of the dash?
Jul 26, 2010 at 3:40 PM
  • 110,194 POSTS
You have a vacuum leak under the dash. The vent doors are actuated by engine vacuum. The added load of the trailer forces the engine to work harder. Thus, intake vacuum is lowered. If there is a slight leak, the lowered intake vacuum and the leak combined allows the air flow to change directions.
Check under the dash. If you are lucky, you will hear a hissing sound with the engine running. If no sound, you have to check visually. Look for cracked, dry rotted lines.
Let me know what you find.
PLEASE NOTE: Check under the hood for the same type of problem if nothing is found under the dash
Jul 27, 2010 at 12:08 AM
